2 Pages12>
tompatriot45
#1 Posted : Thursday, November 14, 2013 6:42:32 AM(UTC)
tompatriot45
Stopped in middle of cycle and clean light flashing. Cannot restart. Turned breaker off and then on and still light flashing. What to do?
Appliance Ninja
#2 Posted : Thursday, November 14, 2013 6:54:46 AM(UTC)
Appliance Ninja
Press the following buttons within 6 seconds....
Hi Temp--Heated Dry--Hi Temp--Heated Dry
All the lights will come on, wait about 30 seconds then press cancel. Make sure the door is closed securely and try another cycle. If it happens again, you have an issue with a component in the heating circuit. Let me know what happens and we can work through it if it starts flashing again.
tompatriot45
#3 Posted : Thursday, November 14, 2013 12:43:53 PM(UTC)
tompatriot45
Tried those steps and still same issue. Next step or suggestion?
Appliance Ninja
#4 Posted : Thursday, November 14, 2013 12:47:44 PM(UTC)
Appliance Ninja
Did the control reset then start flashing clean again during the next cycle?
tompatriot45
#5 Posted : Thursday, November 14, 2013 12:56:08 PM(UTC)
tompatriot45
Yes It did. It started like water was coming in. Ran for about 30-45 seconds. It then shut off and went back to start light flashing. Thanks
Appliance Ninja
#6 Posted : Thursday, November 14, 2013 1:02:35 PM(UTC)
Appliance Ninja
So is the start light flashing or the clean light?
tompatriot45
#7 Posted : Thursday, November 14, 2013 1:11:50 PM(UTC)
tompatriot45
I apologize. It is the clean light that's flashing
Appliance Ninja
#8 Posted : Thursday, November 14, 2013 1:18:02 PM(UTC)
Appliance Ninja
Thank you!
The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Can you see any issues with the heating element, like cracks or holes or any spots that are discolored?
tompatriot45
#9 Posted : Thursday, November 14, 2013 2:02:39 PM(UTC)
tompatriot45
Heating element appears ok. No breaks or discoloration.
tompatriot45
#10 Posted : Thursday, November 14, 2013 2:17:56 PM(UTC)
tompatriot45
One other thing if it is related. When lights are on in any form, I can change selections on panel with door open. Does this make any sense?
DW Repair (Dishwasher Repair)
by Sumold 3/18/2011 12:38:13 PM(UTC)
2 Pages12>
