AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Frigidaire Wont spin at all, replaced motor too!
Originally Posted by: Appliance Ninja  The picture did not come through, sorry. The setting will be marked Rx1 or have a horseshoe looking symbol. When the probes are touched together, the needle should move. It's a digital one. I'm assuming i need to test where the prongs enter the control unit. Assuming I'm doing it right I'm getting nothing on voltage and getting a resistance reading
Are you testing the white fuse that is mounted near the edge of the board?
Originally Posted by: Appliance Ninja  Are you testing the white fuse that is mounted near the edge of the board?  Maybe this will work. The one in the middle? Yes I'm testing it. No reading
Originally Posted by: Appliance Ninja  I hope it's worth it replacing that board in this machine.
If the tub is not real noisy when it spins, it probably is.
Originally Posted by: Appliance Ninja  If the tub is not real noisy when it spins, it probably is. Tub sounds about the same as it did 10 years ago when we got it (minus all that damn change stuck inside it, i need to figure out how to get it out) Thank you for all your help
Receieved the part today. Works like new. Thank you so much
That is great news, nice work! Thank you for taking the time to share your success story, I appreciate that!
Hello Appliance Ninja, I have the same problem - everything except spin. I have replaced the pressure/level switch, the door lock assembly and the speed control board and still no spin. Pump out is fine, fill and water level fine, tub back and forth tumble is fine, just no final spin. Any ideas? Thanks
Washer Repair
