The diagrams are below. Appliance Ninja attached the following image(s):
I verify both and they have continuity. What other part I need to verify?
Okay, so let's get a look at the control board up top. Can you access the back of that board and look fro any poor connections or burnt solder joints on the back of the control, especially by any large relays (usually black and rectangular)?
I verify the board and looks very good, also I disconnect the wire and connected again, but the problem still. The front panel continues turned on but when I pushed any of the push buttons doesn't works.
Can you locate the gray wire that leads from the motor relay on the board to the motor and start the dryer while testing for 120 VAC between that gray wire and any metal on the dryer (ground), please?
Do I need to perform this test with the Dryer connected to the power (electricity)?
Yes, it will need to be plugged in, so be careful. We should see 120 VAC between that gray wire and ground when you push the start button. Let me know what happens, please.
I did it in the motor relay with the grey wire and doesn't have continuity, meanwhile the black wire showed continuity with a ground.
Thanks a lot for your help. I will continue tomorrow in this troubleshooting.
Okay, so you show 120 volts to the black but not the gray? Did you hear the relay click still as you previously were?
