Corey P
#1 Posted : Wednesday, April 29, 2009 11:25:19 AM(UTC)
Corey P
I need to remove a brake and drive tobe assembly on a wirlpool rax7245bw model washer And I do not know how to remove the thrust ring pn AP3018126 and the t-bearing pn AP3890496 can you help
#2 Posted : Wednesday, April 29, 2009 3:22:17 PM(UTC)
You can get the proceedure to remove the spin tube assembly by reading my article in a "sticky" above "replacing direct drive washer brake shoes".
As noted, if you are working on the brake shoes, it is not necessary to remove the spin tube all the way. I use a flat blade screw driver to take off the "C" clips, and use pliers to put them back on.
Corey P
#3 Posted : Thursday, April 30, 2009 5:05:30 AM(UTC)
Corey P
The brake shoes are fine but the c clip groove in the t bearing wont hold the c clip on . It's worn from the bottom and needs to be replaced.I'm not sure if this repair is worth it or not.
#4 Posted : Thursday, April 30, 2009 5:23:34 AM(UTC)
Are you talking about the "C" clip on the tranny spindle??
Corey P
#5 Posted : Thursday, April 30, 2009 5:50:49 AM(UTC)
Corey P
it's the ring that holds on the plastic clutch dog and metal cam on the tube pn AP3018140
#6 Posted : Thursday, April 30, 2009 8:03:11 AM(UTC)
Oh I see now, how in the whorld did this get messed up?? Personally, I would try putting some retaining marks on the end of the spin tube with a metal chisel, worth a try. Otherwise, you will need a new spin tube.
Corey P
#7 Posted : Thursday, April 30, 2009 8:51:56 AM(UTC)
Corey P
Thats not a bad idea but in my case i don't think that there is eouugh material to retain the clip
what do I have to do at the top end of the spindle tube to remove it
#8 Posted : Thursday, April 30, 2009 9:14:25 AM(UTC)
You need to read my sticky article to do this, get the spanner wrench, remove the agitator, loosten the drive block nut, pound down on it with a hammer while lifting up to get it free of the spin tube.
front bearing replacement (Dryer Repair)
by fonzi54 1/17/2011 2:35:11 PM(UTC)
Hot Point Bearing Replacement (Dryer Repair)
by Hopefulnow 2/6/2010 1:54:52 PM(UTC)
