I need to remove a brake and drive tobe assembly on a wirlpool rax7245bw model washer And I do not know how to remove the thrust ring pn AP3018126 and the t-bearing pn AP3890496 can you help
You can get the proceedure to remove the spin tube assembly by reading my article in a "sticky" above "replacing direct drive washer brake shoes". As noted, if you are working on the brake shoes, it is not necessary to remove the spin tube all the way. I use a flat blade screw driver to take off the "C" clips, and use pliers to put them back on.
The brake shoes are fine but the c clip groove in the t bearing wont hold the c clip on . It's worn from the bottom and needs to be replaced.I'm not sure if this repair is worth it or not.
Are you talking about the "C" clip on the tranny spindle??
it's the ring that holds on the plastic clutch dog and metal cam on the tube pn AP3018140
Oh I see now, how in the whorld did this get messed up?? Personally, I would try putting some retaining marks on the end of the spin tube with a metal chisel, worth a try. Otherwise, you will need a new spin tube.
Thats not a bad idea but in my case i don't think that there is eouugh material to retain the clip what do I have to do at the top end of the spindle tube to remove it
You need to read my sticky article to do this, get the spanner wrench, remove the agitator, loosten the drive block nut, pound down on it with a hammer while lifting up to get it free of the spin tube.
