greenfrog1967
#1 Posted : Tuesday, November 12, 2013 7:12:03 AM(UTC)
greenfrog1967
The brand is LG but the drop down menu dose not have that.. ok Im trying to take off the bottom freezer door. I need to replace the icemaker and for my big head to get in there the door needs to come off. I took the drawer out to expose what looks like a screw on both side that might be holding the plastic cover on the rail. I tried to un screw it but striped both of them on both sides. before I drill out the screw is this how to get the door off? I would hate to do more damage or unnecessary work if there is an easier way. Thank you for any input..
Mike
Appliance Ninja
#2 Posted : Tuesday, November 12, 2013 9:12:58 AM(UTC)
Appliance Ninja
Hello! The complete service manual is available below!
LFC25760 Manual
greenfrog1967
#3 Posted : Tuesday, November 12, 2013 9:57:39 AM(UTC)
greenfrog1967
Mike
I figured it out... ;)
greenfrog1967
#4 Posted : Tuesday, November 12, 2013 9:59:17 AM(UTC)
greenfrog1967
LFC25760 Manual
Thanks.. that is good to have..
Appliance Ninja
#5 Posted : Tuesday, November 12, 2013 9:59:20 AM(UTC)
Appliance Ninja
Excellent, very well done! Save that manual for the next problem, it is a valuable resource!
greenfrog1967
#6 Posted : Tuesday, November 12, 2013 10:02:43 AM(UTC)
greenfrog1967
hopefully the icemaker I put in it will solve my problem.. Im assuming its going to take a while for the icemaker to cycle and make ice.. If its not one thing its another and with my luck its something else.
Appliance Ninja
#7 Posted : Tuesday, November 12, 2013 10:07:59 AM(UTC)
Appliance Ninja
It will take some time as the ice maker needs to reach about 15* F before it will begin a harvest cycle. Since it is empty, the first fill will then need to freeze, so it will be at least several hours. I believe you and I share the same luck! :)
