2 Pages<12
iefoaix
#11 Posted : Monday, November 11, 2013 7:32:31 AM(UTC)
iefoaix
It is a 12vDC motor with variable speed which is controlled by another
voltage. The problem is the other voltage is ok (between 5-17v,
P7-9 and P7-10) without the motor connected, but once the motor is
connected, the voltage dropped to below 5v and therefore the motor
does not run.
iefoaix
#12 Posted : Monday, November 11, 2013 7:33:10 AM(UTC)
iefoaix
I am hoping repair the board 2214443 from the following company
will fix the problem.
www.corecentricsolutions.com/WP_Parts_List.html
iefoaix
#13 Posted : Sunday, November 17, 2013 12:22:11 PM(UTC)
iefoaix
This is to update that after replacing the control board 2214443
found on ********, the motor runs and the refrigerator works again.
When disconnected from motor:
Red(+) to White(-): 12v
Yellow(+) to White(-): 0v
Blue(+) to White(-): 0v
When connected with motor:
Yellow(+) to White(-): 5-17v depends on speed
Blue(+) to White(-): 2.78v
That is what it should be. Previously, the Yellow(+) to white(-)
has the correct voltage when disconnected, but the voltage is
dropped when connected.
2 Pages<12
