lkaufman
#1 Posted : Friday, March 2, 2012 4:09:51 PM(UTC)
lkaufman
Hello,
I have a GE undercounter beverage center model ZDB24A RBB. The unit started to freeze all of the soda and juice cans inside. I replaced the thermostat control and the unit continues to do the same. There is not much to this unit. Compressor, run capacitor, PTC relay. Any ideas?
Jerry / APP Team
#2 Posted : Wednesday, March 7, 2012 12:59:44 PM(UTC)
mattt
Hello. The part number you should have installed is [AP2061805]. This is the temperature control. It is the only thing that controls the temperature. If the one you installed is the correct part, and is good the only thing that could be the issue is the placement of the sensing bulb at the end of the long tube made on the temperature control. I sure hope this helped you!
difed
#3 Posted : Sunday, November 10, 2013 2:37:00 AM(UTC)
difed
Originally Posted by: lkaufman Go to Quoted Post
Hello,
I have the same model with the same problem, and was about to purchase an expensive replacement thermostat. Did you resolve your freezing problem? What was the problem?
