AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Maytag Stackable Dryer Buzzer sound, wont start LSE7806ace
When the start button is pushed on Maytag lse7806ace you hear a buzzer sound, like the one when the drying cycle is complete. Thought it was the door switch. When I removed it it appeard like it was fried. Replaced the switch and still didn't work. We bypassed all of the fuses and still would not start. Cleaned out all of the lint and the drum spins freely. Found the buzzer and decided to bypass that and had success! Can I run the dryer without concern with this buzzer bypassed? Thanks in advance for your help.
Originally Posted by: di011361  When the start button is pushed on Maytag lse7806ace you hear a buzzer sound, like the one when the drying cycle is complete. Thought it was the door switch. When I removed it it appeard like it was fried. Replaced the switch and still didn't work. We bypassed all of the fuses and still would not start. Cleaned out all of the lint and the drum spins freely. Found the buzzer and decided to bypass that and had success! Can I run the dryer without concern with this buzzer bypassed? Thanks in advance for your help. any answer to is it safe to bypass buzzer? Thanks, Bill
Ps I have two of these units in my building. so far I have swaped out the electronic control, dryer timer, the thermal fuse and cycling thermostat that are next to each other on the exhaust vent. All to no avail
Originally Posted by: di011361  When the start button is pushed on Maytag lse7806ace you hear a buzzer sound, like the one when the drying cycle is complete. Thought it was the door switch. When I removed it it appeard like it was fried. Replaced the switch and still didn't work. We bypassed all of the fuses and still would not start. Cleaned out all of the lint and the drum spins freely. Found the buzzer and decided to bypass that and had success! Can I run the dryer without concern with this buzzer bypassed? Thanks in advance for your help. Have you noticed any long term effects to bypassing buzzer?
Originally Posted by: Bill Sacto  Ps I have two of these units in my building. so far I have swaped out the electronic control, dryer timer, the thermal fuse and cycling thermostat that are next to each other on the exhaust vent. All to no avail Does bypassing the buzzer cause any long term issue?
Groups: Expert
That is an old thread. Please start a new thread and give dryer model number and symptoms.
Eric
Dryer Repair
