jeslabich
#1 Posted : Wednesday, November 6, 2013 9:06:12 AM(UTC)
jeslabich
Our washer is not working at all right now, after a few weeks of sometimes working and other times not working. Since my husband is an electrician we know it is not an electrical problem, although sometimes when you press power it does nothing. At other times when you press power the start button and minutes button flash but machine does not start. We never see an error code - the machine is just over 3 years old. The lid does lock but then unlocks, and then sometimes locks again. I wonder if we should start by replacing the lid lock but he thinks it might be a control panel. Please help.
fairbank56
#2 Posted : Wednesday, November 6, 2013 9:43:55 AM(UTC)
fairbank56
Groups: Expert
Tilt machine back to retrieve the tech manual from inside the front panel. It will tell you how to get into service mode to check for fault codes and run various tests to try and figure out what's wrong. Sounds like it may be a control board problem. Try reseating all control board wiring connectors as well as connectors at bottom of washer for motor, pump, shift actuator and capacitor. Loose connections and broken wires are very common in these washers. Broken wires are common at wire tie-down points.
Eric
jeslabich
#3 Posted : Wednesday, November 6, 2013 11:26:43 AM(UTC)
jeslabich
Eric
Why can't I find a control board listed in the parts listing for this model Whirlpool Washer?
fairbank56
#4 Posted : Wednesday, November 6, 2013 1:25:26 PM(UTC)
fairbank56
Groups: Expert
There are two circuit boards, the main control and the user interface. Numbers 3 and 6 on the parts page.
02-Console and Dispenser Parts parts for Whirlpool WTW5600XW0 - AppliancePartsPros.com
Eric
Guest (4)
Samsung Frustration (RF31FMESBSR/AA), Writing corrosion (Refrigerator & Freezer Repair)
by innovationhack 5/2/2020 3:20:59 PM(UTC)
f7 e6 frustration (Oven Repair (including Ranges and Cooktops))
by jrsartist 5/16/2014 8:04:38 AM(UTC)
Frustration big time (Washer Repair)
by mranch 7/29/2011 2:07:57 AM(UTC)
Gas Oven/Broiler frustrations (Oven Repair (including Ranges and Cooktops))
by Therm 12/20/2010 1:23:43 PM(UTC)
Spin cycle frustration. (Washer Repair)
by Council2 12/28/2007 6:57:09 PM(UTC)
Dishwasher Frustration! (Dishwasher Repair)
by Gerry 8/12/2007 2:35:24 PM(UTC)
