Hobieone
#1 Posted : 11 years ago
Hobieone
Dryer cuts off when it warms up, will run on air dry only setting. What do I need to replace?
#2 Posted : 11 years ago
You seem to be missing the first 3 digits of the model number.
Hobieone
#3 Posted : 11 years ago
Hobieone
Sorry Denman, 110.82826102
#4 Posted : 11 years ago
Parts for Kenmore Dryer 11082826102 - AppliancePartsPros.com
The Sears parts site does have actual part breakdown diagrams.
Unfortunately they do not share these with other part suppliers.
Can you reatart the unit right away?
if not then it could be the motor is overheating.
This then trips it's internal thermal protect and you have to wait for it to cool down and the protect to reset before it will start.
Check that all the connections are good.
File Attachment(s):
82826102.pdf (407kb) downloaded 6 time(s).
Hobieone
#5 Posted : 11 years ago
Hobieone
The dryer can be started right away, as I said it will run a full cycle as long as heat isn't involved. Is there a thermostatic part that can be replaced?
#6 Posted : 11 years ago
No, there is nothing other than the motpor's thermal protect that should shut the unit off.
The thermal cutoff and the hi-limit thermostat only shut off the heater.
You could check the thermistor with a meter.
It sounds like the heat is causing expansion at a connector or the board and then shutting it down but finding it is going to be a pain.
Might be that the control board is bad.
Hobieone
#7 Posted : 11 years ago
Hobieone
Thanks for your help.
