Belt came off,upon replacing found center broken of pulley,how do i remove this pulley?with the splutch above the pulley there is no room to hold the shaft to keep it from turning
Groups: Expert
Have someone hold the lower agitator and drum from moving while you loosen the nut on whats left of the pulley. With nut off, just pull pulley hub off.
Eric
Seems to be still slipping, I think the splines may be gone. Took out the fabric softener cup and there is a nut holding the agitator in, can I use a wrench to hold it there? Also is the pulley nut reverse thread?
Groups: Expert
Pulley nut is not reverse thread. Holding the agitator bolt will probably just cause that bolt to loosen. Is there nothing left of the pulley to get ahold of? Photo? Maybe use a strap wrench if possible.
Eric
