rberger3
#1 Posted : Wednesday, October 23, 2013 7:34:39 PM(UTC)
rberger3
So i heard a pop and unplugged it.
Found this in the back.
http://i.imgur.com/VumL4Ns.jpg
Checked the thermal fuse and starter fuse and both had continuity.
Can i just replace the cord or is it probably shot?
alina1grace
#2 Posted : Thursday, October 24, 2013 1:34:15 AM(UTC)
alina1grace
Yap You can, and it will start. :)
rberger3
#3 Posted : Thursday, October 24, 2013 3:52:08 PM(UTC)
rberger3
I replaced the cable but it still won't start.
#4 Posted : Friday, October 25, 2013 4:11:00 AM(UTC)
Check the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Note that the black wire at the terminal strip is usually the side of the line that runs the heater but also the motor and timer.
I cannot confirm this to 100% as I cannot find any tech data on this unit.
Do you have the wiring diagram?
it may be stored in the control console.
Guest (6)
Maytag Dryer Not starting (Dryer Repair)
by icetea07 5/31/2017 12:54:26 PM(UTC)
dryer not starting (Dryer Repair)
by DConway0005 3/16/2017 3:40:22 PM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Help! GE dryer not starting (Dryer Repair)
by lelidi 2/4/2015 9:04:46 PM(UTC)
Dryer Not Starting (Dryer Repair)
by dellarte 1/5/2015 5:03:30 AM(UTC)
Maytag Maxima dryer not starting (Dryer Repair)
by ssolle 12/29/2014 8:13:27 PM(UTC)
Dryer not starting (Dryer Repair)
by kbeealexander 6/7/2014 5:59:58 AM(UTC)
by Matt18 11/26/2013 9:56:49 AM(UTC)
Kenmore dryer not starting (Dryer Repair)
by Frustratedinal 5/11/2013 6:18:59 PM(UTC)
Whirlpool Gold gas dryer not starting... (Dryer Repair)
by arvydas512 3/12/2013 10:43:01 AM(UTC)
Maytag Neptune Dryer not starting (Dryer Repair)
by buckeye597 2/17/2013 4:09:06 PM(UTC)
Estate dryer not starting (Dryer Repair)
by lmreese25 2/9/2013 8:06:34 PM(UTC)
Gibson gas dryer not starting (Dryer Repair)
by tad.m 1/31/2013 1:26:02 PM(UTC)
Need help with old Maytag dryer not starting (Dryer Repair)
by momkaren 9/7/2012 6:51:36 PM(UTC)
by Rogscott 4/13/2012 4:34:09 PM(UTC)
