Washed a load as normal, checked it, lights say 21 more minutes, return later to no power, no nothing, load is not finished spinning, still soaking wet. Checked house breaker, it's fine; plugged into another outlet, same. Looked online at manuel and it says without any power need PWB part. Was hoping there might be a "reset" button or something... No error codes to go by, it is just dead! Help!
Groups: APP Team
Originally Posted by: Simon / APP Team  Thank you Simon. I checked and there is 118 volts coming out of the Noise Filter to the PCB. Now is there a way to follow through the PCB to check that? I also checked the power to the F110 part, the control panel with the start switch in it.... the connector at the top left (from power) has very, very small wire connectors... like they are broken off??? When I disconnected it the wires got even smaller! Now Im starting to freak out a little... :) Any suggestions? Thank you! Viktoria
