jimbo
#1 Posted : Wednesday, December 19, 2007 3:46:57 PM(UTC)
jimbo
Side by side unit is 2.5 years old. Noise heard from outside when door closed but louder when door is open. The wind/sound of rushing air surges from time to time and comes from inside the top rear of the freezer. Temp in frig and freezer ok and no other problems noted except the noise. Is this a noisy evap fan? If so, how do you get to it? By removing the ice maker? I can fix about anything with a repair manual but cannot locate one. Thank you.
#2 Posted : Thursday, December 20, 2007 8:22:35 AM(UTC)
Your fridg has the troublesome mother board in the back. It will at times, dump variable frequencies to the evaporator motor. Only solution is a new mother board. Also, good idea to install a 1000 joule surge protector on the outlet.
rsr1977
#3 Posted : Wednesday, April 29, 2009 11:44:23 AM(UTC)
rsr1977
I have the GSH25JSRF SS model (ignore what I wrote in the subject line. it's the wrong model number). I experience the same thing. Would replacing the motherboard fix mine too? Where can I find a new motherboard if it's not under warranty and if there's no recourse via class action?
Thanks everyone!
#4 Posted : Thursday, April 30, 2009 1:20:20 PM(UTC)
If there is exactly the same problem then the correction should be the same too. In regards of the manufacturer warranty you have to talk to GE people.
- The part number for the main control board (#801 on the diagram) is AP4297272
Here are the breakdown diagrams and Replacement parts for GE GSH25JSRFSS | AppliancePartsPros.com
markiee43
#5 Posted : Friday, May 29, 2009 2:37:38 PM(UTC)
markiee43
wll the mother board fix the problem with the ice maker not turning ice out the door water works fine and makes lots of ice but won't come out the front door why is that ?????? anyone know :confused:
#6 Posted : Saturday, May 30, 2009 2:42:09 AM(UTC)
Yes, the motherboard contains the auger motor driver. Replacing the board should fix this problem.
markiee43
#7 Posted : Saturday, May 30, 2009 4:06:41 AM(UTC)
markiee43
thank you for info is there a part# that you could tell to use model # i have is GSH25JSRFSS THANKS AGAIN
#8 Posted : Saturday, May 30, 2009 6:16:13 AM(UTC)
Same # that Gene gave, AP4297272
