I have a KitchenAid KBRA20ELBT that is not cooling in the top refrigerator section or the bottom freezer section. Fan runs until I turn thermostat to off position in refrigerator section. Compressor seems to be cycling on and off; it is silent and then kicks on intermittently then turns off. It is warm to the touch. It makes a noise like the icemaker calling for water; the compressor trying to start. Is this a relay/overload switch problem? gregspigner@msn.com
:cool: Compressor / switch relay overload / other ? I have a KitchenAid KBRA20ELBT that is not cooling in the top refrigerator section or the bottom freezer section. Fan runs until I turn thermostat to off position in refrigerator section. Compressor seems to be cycling on and off; it is silent and then kicks on intermittently then turns off. It is warm to the touch. It makes a noise like the icemaker calling for water; the compressor trying to start. Is this a relay/overload switch problem? gregspigner@msn.com
