When I turn on the oven, it ignites on the first try, and heats to the desired temperature. After a while, the oven doesn't cycle on and off and the temperature drops. I replaced the temperature sensor, but problem still persists. It sounds like a relay in the control panel stays closed preventing it from cycling. When I turn oven off, it sounds like a relay clicks open. Then, I can turn oven on again and it heats up to desired temperature. Any help is appreciated.
I know its been a few years since you posted this, but if you ever figured out the prob, could you please let me know what it was? I am having the same issue and not one person will comment on it.
I'm hoping you can help me out, I really dont want to have to replace 3 major components...
Thanks in adavnce!!!
I replaced the lower igniter and that seemed to do the trick.
Originally Posted by: jwhitcomb  I replaced the lower igniter and that seemed to do the trick. Could you tell me, what kind of ignitor do you / did you have, was it the glow type or more like an ignitor that you find on an outdoor grill (whuch is the style I have) it's riveted to the burner, but does look like it can be taken apart... Again, I appreciate your comments...
