Whizknot
#1 Posted : Monday, October 7, 2013 7:31:01 PM(UTC)
Whizknot
My mother in laws' 1963 double wall oven is on the blink, and there is no wiring diagram, or manuals. I tried sears , and numerous other sources trying to find any info, but have come up empty handed. If anyone has a repair manual or wiring diagram for this old timer ,it would be greatly appreciated. Thanks
P.S. serial # is 6210202
#2 Posted : Tuesday, October 8, 2013 3:44:31 AM(UTC)
I also cannot find any info on the given model number.
Please check it.
I also checked the Sears who makes what and nothing comes up as 403 which is who actually made the unit.
If this is not a USA model then info may not be available on line.
What is the problem?
We may have to trouble shot without any tech info but you have to have a valid model number so you can get parts for it if it needs any.
Need help narrow down oven problem (Oven Repair (including Ranges and Cooktops))
by Guest 7/4/2022 6:46:54 PM(UTC)
Thermador PG304BS/09 Oven Problem (Oven Repair (including Ranges and Cooktops))
by Guest 8/15/2021 7:27:03 PM(UTC)
Range oven problems. (Oven Repair (including Ranges and Cooktops))
by jorge osorio 1/29/2019 1:16:21 PM(UTC)
Oven Problem - lower, no heat; upper A-OK (Oven Repair (including Ranges and Cooktops))
by gesche444 9/15/2017 12:21:36 PM(UTC)
Oven problem (Oven Repair (including Ranges and Cooktops))
by Lhodges 1/28/2017 10:58:04 PM(UTC)
Kitchen Aid oven problem (Oven Repair (including Ranges and Cooktops))
by Rawger11 9/2/2014 11:13:56 AM(UTC)
Maytab oven problem (Oven Repair (including Ranges and Cooktops))
by DJ5140 3/16/2014 8:43:29 AM(UTC)
Whirpool Oven Problems (Oven Repair (including Ranges and Cooktops))
by phsffaman 2/15/2014 6:35:40 PM(UTC)
Oven problem during self clean cycle (Oven Repair (including Ranges and Cooktops))
by cgoetzfried@att.net 1/21/2014 5:48:07 PM(UTC)
kitchenaid oven problem (Oven Repair (including Ranges and Cooktops))
by ticat900 11/25/2013 11:06:28 AM(UTC)
Range/oven Problem (Oven Repair (including Ranges and Cooktops))
by slongo 10/22/2013 5:06:51 AM(UTC)
GE Profile Oven Problems (Oven Repair (including Ranges and Cooktops))
by RSF 10/16/2013 10:23:15 PM(UTC)
self cleaning oven problem (Oven Repair (including Ranges and Cooktops))
by preachergirl09 9/8/2013 11:20:21 AM(UTC)
wall oven problems (Oven Repair (including Ranges and Cooktops))
by jethro75 8/1/2013 6:35:09 AM(UTC)
by jsn.watson1@gmail.com 5/22/2013 8:53:57 AM(UTC)
