kayleediane
#1 Posted : 16 years ago
kayleediane
My dryer was working fine yesterday, I can't remember if I actually started it this morning, but when I went to switch the laundry over the clothes inside were still wet. When my husband was in the shower this morning he said that the water and the lights very briefly shut off. We checked the breaker and that is fine, the belt fine, the pully is fine. The light is not on, when I first checked it this morning you could hear the timer very faintly and then when I tried it again later there was nothing.
kayakcrzy
#2 Posted : 16 years ago
kayakcrzy
you need to replace the thermal fuse. the part # is la-1053. if you unplug the dryer, you will need to pop up the top of the dryer. get a putty knife, and slide it under the top on the right side, about 3 inches from the end, and you will hit a clip to release the top, do the same on the other side, and then push the top back and rest it on the back wall. now, up top, in the rear, right in the middle, is the heating element. on the right side of the element housing, about 6 inches down is the thermal fuse. just follow the 2 white wires. the kit will come with the thermostat mounted on top of the heating element. replace it too. but the most inportant thing to do, is to take off the front and clean the blower housing it is all full of lint. just look inside the front, on the right and left side, about 4 inches from the top is a 1/4 inch screw, remove it on each side, and then lean the front towards you, and take the wires off the door switch, and remember where they go, and then lift up on the whole front, and clean the blower housing. clean the vent hose out behind the dryer, and be sure it is clear to the outside. good luck, and let me know how it goes. tom
#3 Posted : 16 years ago
When you checked the breaker did you just look at it.
If yes, then try turning it off/on slowly a couple times.
It is not uncommon to loose half the line without actually tripping the breaker.
If you have a meter check the voltage at the plug.
Should be 120 volts between L1 and Neutral and between L2 and Neutral.
Also 240 between L1 and L2.
kayakcrzy
#4 Posted : 16 years ago
kayakcrzy
La-1053 is the answer. Cut and dry denman!! No need to complicate it!! Tom
kayleediane
#5 Posted : 16 years ago
kayleediane
what is LA 1053?
kayleediane
#6 Posted : 16 years ago
kayleediane
Never mind figured it out. Thanks.
kayleediane
#7 Posted : 16 years ago
kayleediane
We cleaned everything out last night, we will go and get the part today. I will let you know, thanks for your help.
kayleediane
#8 Posted : 16 years ago
kayleediane
Okay we did what you said and it is working now, but we only had it on for about 15 seconds and it really stinks and my husband seems to think the back of it was warmer than it should be for that short amount of time. Any ideas what might be causing the smell?
kayakcrzy
#9 Posted : 16 years ago
kayakcrzy
The back is where the element is. It should be warmer. Turn the dryer on and go outside where the vent is, and make sure the air is coming out good. The smell might be lint on the element. Tom ApplianceEducator.com
Dryer won't start. Changed all thermostats and fuse (Dryer Repair)
by rudekelly 11 years ago
Whirlpool gas dryer won't start. Fuse is good (Dryer Repair)
by jeffmaaske 13 years ago
Dryer won't start. (Dryer Repair)
by chenrezig12 14 years ago
Dryer won't start. Buzzes loudly when start pressed. (Dryer Repair)
by Spoiler9112 14 years ago
dryer won't start. Timer is just clicking (Dryer Repair)
by dohboy30 15 years ago
Dryer won't start...buzz sound (Dryer Repair)
by RockyRocks 16 years ago
by Rick L. Gardner 16 years ago
Maytag dryer won't start....... (Dryer Repair)
by ShaNene 16 years ago
Roper Dryer won't start... (Dryer Repair)
by deanna08 16 years ago
Whirlpool Electric Dryer won't start. (Dryer Repair)
by tangomacaw 16 years ago
