2 Pages<12
#11 Posted : Friday, October 4, 2013 12:46:56 AM(UTC)
No
An open (infinite resistance) on the lugs on the round part of the cycling thermostat (internal heater) will not cause your problem. The symptom for this would be no low.
When a low heat setting is chosen the internal heater is turned on. This adds heat to the thermostat so it cycles more often resulting in a lower heat output from the main heating element.
Could be that you were just using too low of a meter scale to measure it.
3dDetailer
#12 Posted : Friday, October 4, 2013 7:28:23 AM(UTC)
3dDetailer
Well, it looks like I wore my welcome out here.:( I still don't have an answer, but I guess I'll just take a chance and buy the thermostat first. Thanks for the previous help.
#13 Posted : Friday, October 4, 2013 8:07:56 AM(UTC)
I thought I had answered it!!!
3dDetailer
#14 Posted : Friday, October 4, 2013 9:53:48 AM(UTC)
3dDetailer
Holy moly. You must have posted that just before I posted my last reply.:o
I'm sorry denman.
Quote:
No
Living proof that guesswork is no substitute for an expert.:D
Well, thats odd you should mention that. Yes...I think I did. I just didn't know the scale to use. Well, ok, so I guess that means it's the coils, or can something else in the valve go kuput...like sticking or something? :confused:
What would you do at this point?
#15 Posted : Saturday, October 5, 2013 3:00:52 AM(UTC)
You may want to do some additional troubleshooting on the valve.
Here is a good video about this.
Gas Dryer Repair Video: Heating Problems - YouTube
Note that I am not very good at gas dryer repair.
I do not repair these.
So you may want to start a new post with the model, symptoms (re the igniter is on) etc.
Guest (4)
2 Pages<12
