tsmith7159
#1 Posted : Wednesday, October 2, 2013 4:45:39 PM(UTC)
tsmith7159
Im having issues with my GE Cafe dishwasher not starting, The light on the key pad illuminates when pressed however the dishwasher will not start. Could it possibly be the door switch? If so what is the procedure for testing the switch?
Thank You
HumboldtRepairMan
#2 Posted : Wednesday, October 2, 2013 4:56:37 PM(UTC)
HumboldtRepairMan
Here's some video's to help you out. Also does all the buttons on your touchpad work just not the start button?
dishwasher won't start - YouTube
tsmith7159
#3 Posted : Wednesday, October 2, 2013 5:00:35 PM(UTC)
tsmith7159
All of the buttons appears to be working...the dishwasher just will not start when door is closed.
HumboldtRepairMan
#4 Posted : Wednesday, October 2, 2013 5:02:40 PM(UTC)
HumboldtRepairMan
Does it fill with water?
tsmith7159
#5 Posted : Wednesday, October 2, 2013 5:13:17 PM(UTC)
tsmith7159
No nothing happens, the start light is illuminated when pressed but no water enters machine.
HumboldtRepairMan
#6 Posted : Wednesday, October 2, 2013 5:25:06 PM(UTC)
HumboldtRepairMan
More then likely your touchpad is bad or your main computer board. Look under the unit or behind the panel for the tech sheet it should show you how to ohm test the touchpad. Check for 120v at the main control board from tan to white with the door switch tripped. Ohm test the door switches for continuity.
tsmith7159
#7 Posted : Wednesday, October 2, 2013 5:39:12 PM(UTC)
tsmith7159
Thanks for your help...I will try what you have suggested.
