AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washer will not agitate but will spin out clothes
The washer on wash cycle will not agitate but will spin out clothes when this happened smoke starting coming of the washer and smelled like rubber not electrical smell like a belt. could the problem be the belt and if so with belt and how do I get to the belts. Thanks for all your help in this matter. Tim
Rank:: Advanced Member
Groups: Expert
Belts and pulleys are on bottom of machine. Tilt back for access. Rotate main pulley in center CW for spin, CCW for agitate. If it won't go CCW, check under agitator for clothing jamming it. If that's clear, take the dust cover off the main pulley and inspect the stop lug. The lug is splined to the transmission input shaft. The pulley has a "dog" on it that drives the stop lug which drives the input shaft for agitation. If pulley and stop lug are intact but you can't rotate pulley in CCW direction, the transmission is faulty.
Eric
The pulley moves both cw and ccw. i moved the main pulley by hand and the belt. could the problem be the other belt because when the the washer is suppose to agitate it makes a high squeak and starts to smell like rubber burning. thanks Tim
Groups: Expert
it does drain out it spins and drains out fine with no problem its when it suppose ti agitate that it makes a sound and smells like belt burning. thats why i was wondering about other belt
Groups: Expert
Could still be the pump. Pump rotates in opposite direction during agitation. Need to determine if motor is running or locked up and just humming during agitation.
Eric
Which pulley is the large one or the two small ones thanks sorry for all the questions Ijust want to know what to look for.
Groups: Expert
Motor pulley is on the left, pump on the right, transmission in the middle.
The big pully does not turn when it it is suppose to agitate both small ones on the left turn. I propped the washer back as you said, now what? Thanks Tim
Washer Repair
