3 Pages<123>
Captain SK
#11 Posted : Saturday, September 21, 2013 11:03:35 AM(UTC)
Captain SK
Originally Posted by: BarryDrez Go to Quoted Post
Sorry - I meant to post, but forgot. HumboldtRepairMan was correct. It turned out to be the main board. I shopped around and found one from Sears for under $200. It was not too difficult to replace. Just some wires to unplug and unscrew the board. Took some pictures first to use as a reference for reassembly. Good luck with yours.
Thanks HumboldtRepairMan!
Humboltrepairman might be from my province Saskatchewan.
Too funny
HumboldtRepairMan
#12 Posted : Saturday, September 21, 2013 1:31:08 PM(UTC)
HumboldtRepairMan
Youre welcome
BarryDrez
#13 Posted : Saturday, September 21, 2013 1:58:45 PM(UTC)
BarryDrez
Hi Captain,
It was Sears USA. Did you check the temperature sensor? It is much cheaper than a new main board. There is a good video here that shows you how to test it: Oven Sensor Test - YouTube
This one shows you how to remove it: Oven Temperature Sensor - How To Replace - YouTube
The oven in the video is different than mine, and I had to remove a metal cover on the back of mine to get to the sensor. I paid $53 for my sensor, but it turned out not to be the problem. Luckily, Sears will refund you for the part if you return it within 60 days.
Good luck - Barry
Captain SK
#14 Posted : Saturday, September 21, 2013 2:11:28 PM(UTC)
Captain SK
Hi Captain,
Good luck - Barry
I haven't checked the sensor but considering the problem is absolutely identical to yours I thought for sure mine would be a board replacement. What are your thoughts humboltrepairman?
Captain SK
#15 Posted : Saturday, September 21, 2013 2:16:04 PM(UTC)
Captain SK
Also how do I clear the F6E1 fault code. The panel says to hit the start time button but I don't have one...
BarryDrez
#16 Posted : Saturday, September 21, 2013 3:59:04 PM(UTC)
BarryDrez
Sounds like Whirlpool and Maytag have similar boards. Strange that you don't have the Start Time button. My oven has a set of schematics in a little pouch in the top left back corner. These explain the meaning of the codes and how to reset. Right under the clock are Start and Cancel buttons. When I hit Cancel twice followed by Start, I get a menu that walks me through some settings until I get to the fault codes. Then it tells me how to clear them. Unfortunately, clearing them did not help.
Captain SK
#17 Posted : Sunday, September 22, 2013 7:41:23 AM(UTC)
Captain SK
Bad news. Temp sensor is fine.
I'm going board shopping... :(
BarryDrez
#18 Posted : Sunday, September 22, 2013 11:26:25 AM(UTC)
BarryDrez
Too bad, don't pay over $200 for a board.
Captain SK
#19 Posted : Sunday, September 22, 2013 11:43:50 AM(UTC)
Captain SK
They may be a bit more. Sears Canada is $220
May get lucky and get a used one in town here tommorow too.
BarryDrez
#20 Posted : Sunday, September 22, 2013 2:15:57 PM(UTC)
BarryDrez
Good luck !
Guest (12)
3 Pages<123>
