Originally Posted by: BarryDrez  Sorry - I meant to post, but forgot. HumboldtRepairMan was correct. It turned out to be the main board. I shopped around and found one from Sears for under $200. It was not too difficult to replace. Just some wires to unplug and unscrew the board. Took some pictures first to use as a reference for reassembly. Good luck with yours. Thanks HumboldtRepairMan! Humboltrepairman might be from my province Saskatchewan. Too funny
Hi Captain, It was Sears USA. Did you check the temperature sensor? It is much cheaper than a new main board. There is a good video here that shows you how to test it: Oven Sensor Test - YouTube This one shows you how to remove it: Oven Temperature Sensor - How To Replace - YouTube The oven in the video is different than mine, and I had to remove a metal cover on the back of mine to get to the sensor. I paid $53 for my sensor, but it turned out not to be the problem. Luckily, Sears will refund you for the part if you return it within 60 days. Good luck - Barry
Originally Posted by: BarryDrez  Hi Captain, It was Sears USA. Did you check the temperature sensor? It is much cheaper than a new main board. There is a good video here that shows you how to test it: Oven Sensor Test - YouTubeThis one shows you how to remove it: Oven Temperature Sensor - How To Replace - YouTubeThe oven in the video is different than mine, and I had to remove a metal cover on the back of mine to get to the sensor. I paid $53 for my sensor, but it turned out not to be the problem. Luckily, Sears will refund you for the part if you return it within 60 days. Good luck - Barry I haven't checked the sensor but considering the problem is absolutely identical to yours I thought for sure mine would be a board replacement. What are your thoughts humboltrepairman?
Also how do I clear the F6E1 fault code. The panel says to hit the start time button but I don't have one...
Sounds like Whirlpool and Maytag have similar boards. Strange that you don't have the Start Time button. My oven has a set of schematics in a little pouch in the top left back corner. These explain the meaning of the codes and how to reset. Right under the clock are Start and Cancel buttons. When I hit Cancel twice followed by Start, I get a menu that walks me through some settings until I get to the fault codes. Then it tells me how to clear them. Unfortunately, clearing them did not help.
Bad news. Temp sensor is fine.
I'm going board shopping... :(
Too bad, don't pay over $200 for a board.
Originally Posted by: BarryDrez  Too bad, don't pay over $200 for a board. They may be a bit more. Sears Canada is $220 May get lucky and get a used one in town here tommorow too.
