raldogg22
#1 Posted : Friday, May 13, 2011 6:46:35 PM(UTC)
raldogg22
I have a Kenmore electric dryer (Model No. 110 86568100) that just stopped working last night. I push the start button, but nothing happens. I unplugged the dryer and took off the top of the dryer control panel. Nothing looked to be burned or out of place. Does anyone have any ideas that may help me out? Thank you in advance for any help you can give.
jyama99
#2 Posted : Friday, May 13, 2011 7:46:34 PM(UTC)
jyama99
Check the door switch. Push it in you should hear a click. Most common problem.
#3 Posted : Saturday, May 14, 2011 2:25:09 AM(UTC)
Replacement parts for KENMORE 11086568100 | AppliancePartsPros.com
Check the power.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
Check the thermal fuse (second item in parts list), it is mounted on the blower assembly.
Unplug the unit and check the fuse with a meter should be 0 ohms.
Jiggery Pokery method is.
Unplug the unit.
Remove both wires from the fuse, short them together and tape them up so they will not short to the frame.
Plug the unit in and give it a try.
If blown, replace the fuse ASAP as it is a critical safety device re: prevents lint fires which can turn into house fires.
Also clean/check your vent system and the blower as these are the most common causes of it blowing.
Check the start switch.
paulthetutor
#4 Posted : Friday, September 20, 2013 6:17:42 AM(UTC)
paulthetutor
So far I have had to flip the dryer breakers to get the dryer going twice in about 2 weeks. We inherited a Kenmore Elite HE 110 when we bought our house. I'm wondering if I should do some maintenance on the dryer to see if it is adding pressure on the line. Could a buildup of lint be overheating the unit and making it work too hard?
I'm reasonably handy, but have been a renter for 15 years, so haven't done any sort of dryer work since I left all that to the landlords.
Thanks!
#5 Posted : Friday, September 20, 2013 9:54:45 AM(UTC)
paulthetutor
Is your unit the same model number?
Always a good idea to clean/check the vent system every year of at least every second year.
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
