freezer and refrigerator get cold but freezer does not freeze put new defrost timer and all is working with refrigerator shut down and start up after 20 minutes defrost problem is the freezer still stays cold but does not freeze i am at wits end could you help me to check ou something
Groups: APP Team
Hi. Check if the evaporator fan is running. Open the rear panel in the freezer and check the frost pattern on the evaporator coils. If it only partially covered with frost you most likely have a sealed system problem and need a professional assistance. If the coils are blocked with snow that's most likely defrost failure. Check continuity of the defrost heater and defrost thermostat Part number: AP3108454
The Whirlpool refrigerator is a brand that has been trusted for many years. The name Whirlpool is synonymous with quality in appliances. They have many innovative appliances that are not just for use in your kitchen but also in your laundry room and other areas of your home as well. If you are looking to replace your old refrigerator or you need to buy a new one to put in your first home you can't go wrong with a quality fridge like a Whirlpool refrigerator. Four Basic Types Of Whirlpool Refrigerator: 1. The side by side: this type of fridge has the refrigerator section and the freezer section vertically parallel to each other. The sides are similar in size and it is one of the bigger refrigerators, so you will need more space than for some other Whirlpool refrigerator models. 2. The Freezer on top model is one of the more popular refrigerator models. It is the kind that most people currently own. You can customize it with many different features. 3. The freezer on the bottom model is quickly gaining in popularity as a Whirlpool refrigerator because it puts the fresh ingredients and those you use most often at eye level. For those who have problems bending over, this may be a great solution. 4. The compact refrigerator has all of the features of a larger fridge but it can fit in a really small space such as those you might find in an apartment or dorm room. You can fit this type of Whirlpool refrigerator in your office as well. For Other Information about whirlpool refrigerator you can read at whirlpool refrigerator website.
