mattgumaer
#1 Posted : Wednesday, September 18, 2013 7:02:29 PM(UTC)
mattgumaer
My dishwasher started not filling some initial troubleshooting revealed that the float valve switch was broken (no continuity and floppy leaf spring). I ordered and received a new one from here and installed. Still no water. I checked the water supply (ok) and then checked to see if with the new float valve switch, I was getting power to the fill valve solenoid. I am not. So, I took out the new float valve switch and tested for continuity. There is continuity both with the leaf spring depressed and without it depressed which is confusing both because with continuity, I'm not sure why I'm not getting power to the fill valve solenoid and I'm not sure if I did, how the water is ever going to turn off via the float valve if it ever starts to fill. Any ideas would be greatly appreciated. Time for a new dishwasher?
Matt
#2 Posted : Thursday, September 19, 2013 1:17:22 AM(UTC)
[COLOR="Blue"] There is continuity both with the leaf spring depressed and without it depressed which is confusing both because with continuity,[/COLOR]
Sounds like the switch is defective.
With the switch depressed it should be 0 ohms.
With it not depressed it should be infinite ohms.
[COLOR="Blue"] I'm not sure why I'm not getting power to the fill valve solenoid and I'm not sure if I did, [/COLOR]
Sorry but I do not understand the above.
[COLOR="Blue"]how the water is ever going to turn off via the float valve if it ever starts to fill.[/COLOR]
The fill cycle is a timed event.
The overfill switch is just a safety device.
Check the wiring from the control board down to the fill parts.
If OK then you need a new control board.
mattgumaer
#3 Posted : Thursday, September 19, 2013 5:56:02 PM(UTC)
mattgumaer
Thanks Denman. Makes sense.
Matt
GE Dishwasher won't fill after grease (Dishwasher Repair)
by Guest 1/1/2022 3:18:27 PM(UTC)
Maytag dishwasher won't fill (Dishwasher Repair)
by dkirchner2@wi.rr.com 11/5/2014 5:40:40 AM(UTC)
Dishwasher won't fill or run (Dishwasher Repair)
by kevin.atkinson 11/28/2013 4:56:56 PM(UTC)
Dishwasher Won't Fill (Dishwasher Repair)
by Rjkaster 1/12/2013 9:48:06 AM(UTC)
Dishwasher won't fill (Dishwasher Repair)
by SpedG 4/4/2012 8:23:34 AM(UTC)
Dishwasher won't fill, hasn't been used for months (Dishwasher Repair)
by talentetta 1/15/2012 10:49:50 AM(UTC)
GE Dishwasher won't fill (Dishwasher Repair)
by brotherleeroy 12/21/2011 9:53:36 AM(UTC)
Bosch dishwasher won't fill (Dishwasher Repair)
by sparky296 6/29/2011 1:17:33 PM(UTC)
Dishwasher Won't Fill -- Replaced Inlet Valve (Dishwasher Repair)
by wildwind 6/2/2011 12:23:53 PM(UTC)
by segriggs 3/21/2011 10:45:58 AM(UTC)
Dishwasher won't fill and pump is loud (Dishwasher Repair)
by angelo c 3/7/2011 5:41:40 PM(UTC)
Dishwasher won't fill (Dryer Repair)
by idgie 1/24/2011 5:44:35 AM(UTC)
Maytag Dishwasher won't fill w/ water (Dishwasher Repair)
by boehlcj 1/12/2011 4:31:14 PM(UTC)
Kenmore Dishwasher won't fill up to wash. (Dishwasher Repair)
by Samuel Murphy 10/28/2010 8:04:26 PM(UTC)
My Ge dishwasher won't fill up all the way (Dishwasher Repair)
by taushabrady 10/2/2010 2:53:25 PM(UTC)
