guelph_geek
#1 Posted : Thursday, September 12, 2013 10:34:50 AM(UTC)
guelph_geek
We have an electric range that it seems everything works except the oven. It goes on pre heat but nothing happens. Ran diagnostics and I do see one strange code of 3Cf and I don't know what that means. Any help is appreciated !
HumboldtRepairMan
#2 Posted : Thursday, September 12, 2013 3:19:31 PM(UTC)
HumboldtRepairMan
Here's some video's to help you figure it out
http://www.youtube.com/results?...1.11.youtube.Earx7ShOR_M
guelph_geek
#3 Posted : Saturday, September 14, 2013 9:17:25 AM(UTC)
guelph_geek
Thanks ! I'll grab my test meter and get to work this afternoon. Appreciate it !
Cheers
guelph_geek
#4 Posted : Sunday, September 22, 2013 11:36:42 AM(UTC)
guelph_geek
So what I did so far was to remove and check the thermal fuse. My multimeter ( set on 200) gave a reading of 0.8. Next I checked the sensor. I did manage to get about 1080 ohms but also noticed that when I removed it and gently shake it rattles, is that normal ? Both bake and broil elements gave readings so I'm assuming they are ok and conducting. Still can't find what the one code means and now wondering if there is a way to test the control unit itself ?
