dante fix
#1 Posted : Monday, September 9, 2013 7:37:11 PM(UTC)
dante fix
I'm having problems with the washer agitating, I have opened the front and inspected the belt and the 2 pulleys, they where both spinning. What are some of the things that I need to check? Please help.:confused:
fairbank56
#2 Posted : Tuesday, September 10, 2013 3:19:36 PM(UTC)
fairbank56
Groups: Expert
The splines in the agitator coupler may be stripped out. Can you grab the lower agitator fins and rotate the agitator? If so, remove the agitator by placing a strap under it and yanking upwards forcefully to pop it off, then remove the bolt holding the coupler down.
GE WH49X10042 Washer Agitator Coupler Kit - AppliancePartsPros.com
Eric
dante fix
#3 Posted : Tuesday, September 10, 2013 5:19:43 PM(UTC)
dante fix
Fairbank56
I forgot to tell you that it does spin dry. I grabbed the lower agitator and was able to spin it. Should I still change the agitator coupler?
dante fix
#4 Posted : Tuesday, September 10, 2013 5:30:07 PM(UTC)
dante fix
Fairbank56
After more inspection of the agitator coupling it is stripped. Thanks again.
Guest (4)
GE won't agitate (Washer Repair)
by Marc71 4/28/2008 10:28:38 AM(UTC)
