Westbank
#1 Posted : Tuesday, April 28, 2009 5:19:52 AM(UTC)
Westbank
My 8 months old KitchenAid dishwasher is making an unpleasant noise when I open/close the door. I made a service call few weeks ago when the problem started. A technician from Whirlpool came and simply sprayed liquid grease on the lanyards and pulleys. It's was quiet for about 2 weeks.
Now I don't want to pull the dishwasher every few weeks to put more grease. I searched the web and I found this: http://appliancejunk.com...s/index.php?topic=2123.0
It seems like Whirlpool is now making a door balance kit with two pulleys.
I called Whirlpool again to get this new door balance kit installed as it would fix the problem permanently. Sadly, they don't have access to that kit which I find pretty strange.
So I want to order this kit from the net and install it by myself. So I would like to know where to order the part from ? AppliancePartsPros doesn't have the new version of the kit with the two pulleys.
IceMan309
#2 Posted : Tuesday, April 28, 2009 7:19:13 AM(UTC)
IceMan309
The link below has this part in stock
http://www.********************...59756&PartID=1059756
Hope this helps!
Iceman
IceMan309
#3 Posted : Tuesday, April 28, 2009 7:21:24 AM(UTC)
IceMan309
http://www.************************....PartID=1059756
Hope this helps!
Iceman
Westbank
#4 Posted : Tuesday, April 28, 2009 7:27:51 AM(UTC)
Westbank
IceMan309
It seems like the link is censored ? Everything between www and com is a bunch of asterisk.
Westbank
#5 Posted : Tuesday, April 28, 2009 7:31:15 AM(UTC)
Westbank
Iceman309
I finally figured out the url. The kit on that site is identical to what I have right now. It only has one pulley at the bottom and not two.
IceMan309
#6 Posted : Tuesday, April 28, 2009 7:39:00 AM(UTC)
IceMan309
Did the page offer the 1059756 kit? It shows 2 pullleys and 2 lanyards. I understood this to be the new kit from the link that I found.
Do you need me to help you more with this issue?
Iceman
Guest (4)
