Sounds like we have different problems. I haven't had time to test my Tstat yet. The mighty google tells me your flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection. So its your air damper thats bad. [FIXED] Flashing Number 4 on Refrigerator sidePunch your model number into this site to get you part number for the damper and then punch that mfg part# into google shopping to get the lowest online price. But then check ******** anyway cause there are people that will cannibalize old appliances for these parts cheap.
Originally Posted by: Tashi54 Sounds like we have different problems. I haven't had time to test my Tstat yet. The mighty google tells me your flashing #4 occurs when power is applied to the fridge and the control board goes through it's cycles and didn't detect a damper connection. So its your air damper thats bad. [FIXED] Flashing Number 4 on Refrigerator sidePunch your model number into this site to get you part number for the damper and then punch that mfg part# into google shopping to get the lowest online price. But then check ****** anyway cause there are people that will cannibalize old appliances for these parts cheap. *e-b-a-y* Sorry APP.com but it's true.
Thanks for the detailed reply. After unplugging for 24 hours and then plugging back in, my fridge mysteriously started working again and the flashing 4 went away.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a frigidaire FGHB2866PP3 GALLERY. We had a power outage for about 24 hrs. Now nothing is coming on (no control panel, no lights, and no conpresser). I checked the outlet it is plugged into and it is still working.
Rank: Guest
