AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
key pad beeps repeatedly & won't rest or turn off
Keypad displays delicate cycle 36 minutes & won't reset. Beeps repeatedly & won't turn off. Dryer will run I this cycle but repeatedly beeps for no reason. Unplugging did not help. Turns itself back on to same cycle. Will not turn off to allow me to run diagnostic check.
Here are your parts Parts for Kenmore Dryer 11062062102 - AppliancePartsPros.comSee the attachment for the tech sheet. Sounds like either a control board or a control panel (keypad) problem. You will have to check the control panel (see the tech sheet). If it checks out (diagnostics and using a meter) OK then I would order the control board (AP3841386). If the panel (AP3100637) does not check out then the unit may be toast as it looks like this part is obsolete though I would call them just to be sure. |
THIS FORUM IS DEAD!!!!!!! |
Dryer Repair
