mreeves
#1 Posted : Friday, September 6, 2013 6:33:08 PM(UTC)
mreeves
Keypad displays delicate cycle 36 minutes & won't reset. Beeps repeatedly & won't turn off. Dryer will run I this cycle but repeatedly beeps for no reason. Unplugging did not help. Turns itself back on to same cycle. Will not turn off to allow me to run diagnostic check.
#2 Posted : Saturday, September 7, 2013 3:29:56 AM(UTC)
Parts for Kenmore Dryer 11062062102 - AppliancePartsPros.com
Sounds like either a control board or a control panel (keypad) problem.
You will have to check the control panel (see the tech sheet).
If it checks out (diagnostics and using a meter) OK then I would order the control board (AP3841386).
If the panel (AP3100637) does not check out then the unit may be toast as it looks like this part is obsolete though I would call them just to be sure.
File Attachment(s):
62062102.pdf (381kb) downloaded 7 time(s).
Guest (4)
