Hi, I’ve got a Model = LSR8233E OR LSR8233EQO SERIAL = CG22229083 Whirlpool Ultracare heavy duty Super Capacity Plus Supreme 8 cycle 2 speed motor . It's a rebuilt one The unit was working until I heard a really bad noise when it was trying to engage the agitation. I thought maybe the “cams” had gone bad again, (I’d replaced them about a year ago w/your “Medium Cam Agitator Repair Kit) ,as the agitator wasn’t doing anything, but then it came out of it. Now the agitator won’t spin and it appears to go through it’s cycle and the pump is working. I’ve a feeling after looking at some online questions from other people that the clutch might be the issue. This means I’d have to order Clutch Assembly OEM Part Number: AP3094537. I can hear the unit running quietly, just not doing any agitating or spin drying either. Only the pump seems to be doing it’s job. From what I’ve described to you, does this appear to be what you think might be the solution as well?
Groups: Expert
You need a motor coupler, not a clutch. The clutch only affects spin. A bad coupler will affect both agitation and spin and can make a lot of noise.
Eric
