bsuderski
#1 Posted : Wednesday, September 4, 2013 1:16:40 PM(UTC)
bsuderski
Please Help. Yesterday our washer stopped spinning and would not drain. After some research I took it apart and checked the clutch and the motor coupler. The clutch seemed ok. It was very hard to turn. The coupler was completely round in the center so I replaced it. Ran a test load and the washer worked. But, not it makes a high pitched sound and has a burning smell. any help is appreciated.
fairbank56
#2 Posted : Wednesday, September 4, 2013 3:37:25 PM(UTC)
fairbank56
Groups: Expert
You didn't get the coupler halves on far enough. They must be flush with the end of the shafts. Use a socket and hammer to tap them on.
Eric
bsuderski
#3 Posted : Wednesday, September 4, 2013 5:10:02 PM(UTC)
bsuderski
Thank you for the reply. After I posted this I found a similar post which said the same thing. Did it and is working just fine now. I really appreciate this forum.
Brian
