I do not think there are other reliable ways. You have to have a simple multimeter and they are about $20 only. No one water filter lasts more than 1 year.
That mean I have to change water filter and have to test like you said ? Ok i will try ,thank so much and let you know after I do
Hello , I back, I just checktest piont between N and L they are 120 v and short piont T H to run the moter , yes , I Leave the jumper in for a half of a revolution and remove and the moter still run for half more revolution then stop but water still not come out . What next I do ? How we know inlet vale work or not ,show me how to test . Thanks for help
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Thanks for reply, but the water line two diference side can't fix another line ? Inlet valve part# AP3160649 ,they have 1 small ( red ) hole and other bigger (green ) how can I swap ? and the water line is clear
Originally Posted by: ngoc101  Thanks for reply, but the water line two diference side can't fix another line ? Inlet valve part# AP3160649 ,they have 1 small ( red ) hole and other bigger (green ) how can I swap ? and the water line is clear Being careful to not touch the wire with your bare hands, just hold them to the other connectors while someone trys the water dispenser.
OK I swapp the wires ,then try the water dispenser and nothing happen ,no water come out to ice maker ,please advive Thank you
Check the water feeding tube into the ice maker. If it's not frozen then the water inlet valve is bad.
Hi , if I order inlet valve then still not working ,I can return
You have to address such questions to the customer service. I do not work for Appliance Parts Pros.
