2 Pages<12
#11 Posted : Monday, April 13, 2009 1:12:23 PM(UTC)
I do not think there are other reliable ways. You have to have a simple multimeter and they are about $20 only. No one water filter lasts more than 1 year.
ngoc101
#12 Posted : Monday, April 13, 2009 2:22:54 PM(UTC)
ngoc101
That mean I have to change water filter and have to test like you said ?
Ok i will try ,thank so much and let you know after I do
ngoc101
#13 Posted : Saturday, April 25, 2009 8:15:11 AM(UTC)
ngoc101
Hello ,
I back, I just checktest piont between N and L they are 120 v and short piont T H to run the moter , yes , I Leave the jumper in for a half of a revolution and remove and the moter still run for half more revolution then stop but water still not come out . What next I do ? How we know inlet vale work or not ,show me how to test .
Thanks for help
woodchuckie
#14 Posted : Saturday, April 25, 2009 2:40:28 PM(UTC)
woodchuckie
Rank:: Advanced Member
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
ngoc101
#15 Posted : Sunday, April 26, 2009 12:13:34 PM(UTC)
ngoc101
Thanks for reply, but the water line two diference side can't fix another line ? Inlet valve part# AP3160649 ,they have 1 small ( red ) hole and other bigger (green ) how can I swap ? and the water line is clear
woodchuckie
#16 Posted : Sunday, April 26, 2009 3:23:32 PM(UTC)
woodchuckie
Being careful to not touch the wire with your bare hands, just hold them to the other connectors while someone trys the water dispenser.
ngoc101
#17 Posted : Monday, April 27, 2009 5:06:59 PM(UTC)
ngoc101
OK I swapp the wires ,then try the water dispenser and nothing happen ,no water come out to ice maker ,please advive Thank you
#18 Posted : Monday, April 27, 2009 5:26:44 PM(UTC)
Check the water feeding tube into the ice maker. If it's not frozen then the water inlet valve is bad.
ngoc101
#19 Posted : Monday, May 4, 2009 8:36:29 AM(UTC)
ngoc101
Hi , if I order inlet valve then still not working ,I can return
#20 Posted : Monday, May 4, 2009 8:53:51 PM(UTC)
You have to address such questions to the customer service. I do not work for Appliance Parts Pros.
2 Pages<12
