Tim-in-AZ
#1 Posted : Wednesday, August 21, 2013 4:07:23 PM(UTC)
Tim-in-AZ
I've replaced just about everything I can think of: defrost timer, evaporator fan assembly, thermostat, and the freezer control switch/dial.
I've cleaned the coils under the fridge and the evaporator coils get cold and ice over/defrost just fine. When I replaced the fan itself it came on briefly but hasn't worked since. The last part I replaced was the freezer control switch which the customer service guy said was probably the last thing he could think of that would prevent it from working; but apparently there's something else left that I'm missing. Are there any other boards or control units that would directly affect the fan or am I just out of luck and need to buy a whole new fridge?
Tim-in-AZ
#2 Posted : Thursday, August 22, 2013 7:54:46 PM(UTC)
Tim-in-AZ
Need help!!!
#3 Posted : Friday, August 23, 2013 2:03:27 AM(UTC)
I am not sure which thermostat you changed (main temperature control thermostat or the defrost thermostat.
The circuit path for the evaporator fan is
H, red wire
Main control thermostat
Yellow wire
Evaporator fan
Brown wire
Defrost thermostat
Orange wire
Defrost heater
White wire
Neutral
The current for the evaporator fan is low so the defrost heater does not heat up with the fan's current flowing through it.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
ARS2667.pdf (346kb) downloaded 8 time(s).
Tim-in-AZ
#4 Posted : Friday, August 23, 2013 8:05:49 PM(UTC)
Tim-in-AZ
I looked at the diagram for a bit and I'm still a bit at a loss as to what to check.
The thermostat I replaced was the one that clips on to the top of the cooling coils (just below the evaporator fan).
I'm not quite sure what you mean about the fan and defrost heater.
Tim-in-AZ
#5 Posted : Friday, August 23, 2013 10:19:09 PM(UTC)
Tim-in-AZ
Well, this is an odd development: I tested one of the pins on the motor to earth ground and it showed 110V. Touch the GRN/YEL wire to the motor pin and the fan came on. I guess the brown wire isn't grounding somewhere in the path and it's preventing it from closing the circuit. I haven't had a great deal of time to study the wiring diagram, but at least I have something to work with.
Any suggestions from the experts?
#6 Posted : Saturday, August 24, 2013 1:18:51 AM(UTC)
I would check the defrost heater, should be around 30 ohms.
Tim-in-AZ
#7 Posted : Saturday, August 24, 2013 8:01:50 AM(UTC)
Tim-in-AZ
28.8ohms according to my meter (not the most accurate one in the world).
#8 Posted : Saturday, August 24, 2013 10:16:06 AM(UTC)
28.8 is good.
Guest (5)
