alohamomma
#1 Posted : Friday, August 23, 2013 9:17:05 AM(UTC)
alohamomma
Hello-
I have a Roper gas oven that will heat up to desired temperature then shut off. It will not go back on until the oven cools off, usually somewhere in the 200 degree range. It does not matter what the set temperature is, 300-500, it will always reach the set temp then it shuts off. ANy idea what this could be? Thank you!
randylewis
#2 Posted : Friday, August 23, 2013 4:57:07 PM(UTC)
randylewis
Originally Posted by: alohamomma Go to Quoted Post
Hello-
Do you have a model # ?
alohamomma
#3 Posted : Friday, August 23, 2013 8:03:52 PM(UTC)
alohamomma
Yes...model #B8758b2. Thank you!
alohamomma
#4 Posted : Sunday, September 8, 2013 12:29:15 PM(UTC)
alohamomma
bump (thank you!)
