Hello-
I have a Roper gas oven that will heat up to desired temperature then shut off. It will not go back on until the oven cools off, usually somewhere in the 200 degree range. It does not matter what the set temperature is, 300-500, it will always reach the set temp then it shuts off. ANy idea what this could be? Thank you!
Originally Posted by: alohamomma  Hello-
I have a Roper gas oven that will heat up to desired temperature then shut off. It will not go back on until the oven cools off, usually somewhere in the 200 degree range. It does not matter what the set temperature is, 300-500, it will always reach the set temp then it shuts off. ANy idea what this could be? Thank you! Do you have a model # ?
Yes...model #B8758b2. Thank you!
