tommmckinney
#1 Posted : Friday, August 23, 2013 8:26:27 AM(UTC)
tommmckinney
Dryer cuts off and starts beeping after 2 to 3 minutes with a message saying call for service E 64
HumboldtRepairMan
#2 Posted : Friday, August 23, 2013 6:16:59 PM(UTC)
HumboldtRepairMan
Take the dryer apart there should be a tech sheet inside, your having a problem with the heating circuit. Ohm test all the thermostats in that circuitry you probably have something burned out somewhere. Here's your wire schematics and parts. Good luck
Parts for Frigidaire FASE7074LR0 Dryer - AppliancePartsPros.com
#3 Posted : Saturday, August 24, 2013 4:40:49 AM(UTC)
Below is a more legible wiring diagram.
Just in case the tech sheet is not with your unit.
http://manuals.frigidaire.com/p...df/Webster/137507300.pdf
I could not find one for your unit so it is for a FASE7074NA2.
As far as I can see the only difference is that this unit has a drum light so the door switch is different.
