2 Pages12>
kylekyle
#1 Posted : Monday, April 27, 2009 5:33:27 AM(UTC)
kylekyle
Yesterday my refrigerator temperature read 50 degrees and stayed that for a few hours before gradually lowering to 46 after 4 hours . I am not sure why. It was 90 degrees outside but that should not affect it. The refrigerator was not left open. Today it is down to 38 degrees.
What could have caused the temperature to be so high?
#2 Posted : Monday, April 27, 2009 5:54:30 AM(UTC)
Check and clean the condenser coils under the fridge.
Check that the compressor fan runs.
Outside/ambient temp will effect the efficiency of the fridge.
kylekyle
#3 Posted : Monday, April 27, 2009 10:12:57 AM(UTC)
kylekyle
I am not at the refrigerator now but the freezer is now too warm. The refrigerator came back to 38 degrees down from 50 yesterday. The freezer read 18 yesterday and still reads 18 today.
4 months ago the refrigerator was too cold. I paid GE to install a wr49x10091 AASM COVER FF INLET. I do have a warranty from GE on this part so is there a good chance that this might be the probelm again.
#4 Posted : Monday, April 27, 2009 12:13:02 PM(UTC)
Did you do it?
The part you mentioned would not cause such problem in the freezer.
kylekyle
#5 Posted : Monday, April 27, 2009 12:21:47 PM(UTC)
kylekyle
Did you do it?
I have been at work since getting the first reply so I have not yet done it. I was trying to see if the previous problem was related.
kylekyle
#6 Posted : Monday, April 27, 2009 12:44:03 PM(UTC)
kylekyle
is there something in a sticky or another thread that tells me how to check if the compressor fan runs?
in addition, the refrigerator is very heavy. How do you recommend getting the coils under the fridge?
#7 Posted : Monday, April 27, 2009 4:54:27 PM(UTC)
You will have to pull it away from the cabinets.
Remove the front kick plate and the rear access panel.
You will see the compressor fan so can tell if it is running.
Be careful not to ruin your floors. Running it on cardboard helps. My brother-in-law has a set of interlocking plastic tracks to run the wheels on seems to work OK.
kylekyle
#8 Posted : Tuesday, April 28, 2009 6:20:35 AM(UTC)
kylekyle
I was not able to move it yet. I need to get my son to help me move the refrigerator so I have not done it yet.
We do have a lot of stuff in the freezer. Is it at all possible that if there is a lot in the freezer that this could cause the temperature problem.
The current temperature in the freezer is 25 degrees and the refrigerator is 40 degrees.
My son is suggesting that we have too much stuff in the freezer and we only need to move stuff out of the freezer and there will be no more problem.
#9 Posted : Tuesday, April 28, 2009 6:24:43 AM(UTC)
If you are blocking the vents to the evaporator coils it could cause problems.
kylekyle
#10 Posted : Tuesday, April 28, 2009 6:35:13 AM(UTC)
kylekyle
is there a particular shelf or shelvers of the freezer that the vents to the evaporator are usually on.
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
2 Pages12>
