Hi, I just replace the bake igniter in my GE range. The old igniter showed burn marks on the wire insulation (see picture). The burned part of the insulation was hard/non-flexible. Is this normal? Is it safe? Is there a problem with the oven that needs to be fixed? Thanks pbillow attached the following image(s):
Did you continue to have problems. My maytag oven igniter looks exactly the same
