pbillow
#1 Posted : Sunday, January 31, 2010 11:17:12 AM(UTC)
pbillow
I just replace the bake igniter in my GE range. The old igniter showed burn marks on the wire insulation (see picture). The burned part of the insulation was hard/non-flexible. Is this normal? Is it safe? Is there a problem with the oven that needs to be fixed?
pbillow attached the following image(s):
Ndell
#2 Posted : Tuesday, August 20, 2013 3:52:00 PM(UTC)
Ndell
Did you continue to have problems. My maytag oven igniter looks exactly the same
