My refrigerartor accumulates a large amount of water in the bottom recess about every seven days. If I don't keep an eye on it - it will start leaking out onto the floor. What's up with that?
[FONT='Times New Roman'] The drain is stopped up and must be cleaned out to fix your problem. To do this remove the evaporator cover under the cover you should see a hole covered with ice. Remove the ice (careful not to punch a hole in the drain pan if using an ice pick) then clear the drain. To do this I force hot water down the drain with a turkey baser but you can use any squirt bottle I have even used a garden hose. Once the drain is clear mix baking soda with water and pour it down the drain to prevent this from happening any time soon. Refrigerator Leaking Repair Guide[/FONT]
Where exactly would the evaporator cover be on this fridge?
Originally Posted by: woodchuckie  Just to confirm, The cover is inside the freezer compartment on the back side. Will i need to remove the ice maker to gain access? Is removal of the ice maker a big deal?
The cover may not extend behind the ice maker but if it does the ice maker hangs on brackets and is held secure by screws. Loosen the screws and lift the ice maker up and unplug the wiring harness.
I'm also needing cabinet parts for this fridge. It's an Amana ART2105BW. Everywhere I go I get parts are no longer available. Is there anyone out there that handles discontinued parts? Or am I just out of luck?
