kcjonz
#1 Posted : Monday, August 19, 2013 12:49:06 PM(UTC)
kcjonz
Whirlpool oven turns on and preheats normally, then sometime during baking the elements stop heating. Lights and control board function normally and the heat light is lit indicating an element is on. Upon cycling power neither element will heat. Checked the breaker and it is not tripped. I cycled the breaker several times and then finally both elements work again.
I thought it was a fluke and then 2 days later the same thing.
I am uncertain if flipping the breaker is causing the oven to come back on or if it is due to the oven having time to cool down that allows it to work again.
My thoughts are either
1)One leg of the breaker is going bad and getting flaky under load.
2)Temperature safety switch in the oven going bad
Any thought would be appreciated.
HumboldtRepairMan
#2 Posted : Monday, August 19, 2013 3:56:43 PM(UTC)
HumboldtRepairMan
Can't help without a model number
kcjonz
#3 Posted : Tuesday, August 20, 2013 6:16:45 AM(UTC)
kcjonz
Gbs307prb01
Whirlpool WRF535SWHZ07 Won't Program Control Board (Refrigerator & Freezer Repair)
by Guest 7/5/2024 1:43:28 AM(UTC)
WRF989SDAM03 Whirlpool fridge making ice very slowly (Refrigerator & Freezer Repair)
by BlueWRXPride 6/20/2024 5:24:45 PM(UTC)
Whirlpool dryer light (Dryer Repair)
by Guest 6/19/2024 12:27:19 PM(UTC)
Whirlpool fridge WRF560SFYM02 (Refrigerator & Freezer Repair)
by Guest 6/15/2024 5:02:08 AM(UTC)
Whirlpool Oven/Microwave combo E1 F2 (Oven Repair (including Ranges and Cooktops))
by MalcolmR 6/12/2024 10:02:00 AM(UTC)
Whirlpool cont. clean stove SF330 PERN6 (Oven Repair (including Ranges and Cooktops))
by bruce.kolozy@att.net 6/10/2024 2:55:08 PM(UTC)
Whirlpool Gold Accubake Oven/Microwave (Oven Repair (including Ranges and Cooktops))
by Guest 6/10/2024 10:21:28 AM(UTC)
Whirlpool wtw500dw1 won't fill (Washer Repair)
by Guest 6/9/2024 4:14:40 PM(UTC)
Whirlpool duet washer front load (Washer Repair)
by Guest 6/3/2024 9:57:09 AM(UTC)
Whirlpool LA5700XTN0 won't agitate (Washer Repair)
by Kyou 6/2/2024 5:13:20 PM(UTC)
Whirlpool Flame Cuts off After 5-10 seconds (Dryer Repair)
by Guest 6/1/2024 8:00:29 AM(UTC)
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 5/15/2024 5:37:40 AM(UTC)
Whirlpool Duet Sport wgd8300sw0 - drying time takes forever (Dryer Repair)
by mattyP4321 5/14/2024 8:34:23 AM(UTC)
Whirlpool Fridge odor (Refrigerator & Freezer Repair)
by Guest 5/14/2024 4:46:42 AM(UTC)
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
