tfdavis
#1 Posted : Friday, August 16, 2013 12:15:52 PM(UTC)
tfdavis
I replaced the door gasket today because the top was leaking air. Now the door will not close. No suction to hold it shut.
HumboldtRepairMan
#2 Posted : Friday, August 16, 2013 4:37:15 PM(UTC)
HumboldtRepairMan
Could of gotten the wrong part you sure you ordered the right model? Your best bet is to call a repairman because if you can't figure out a gasket you need an expert to help you before you ruin the gasket trying to adjust it and permanently damaging it and or the door hinge. Good luck
