I'm trying to locate the defrost timer on my Amana bottom freezer refrigerator. Any clues?
Its typically always up inside the lighting cavity in the fresh food area on top disassemble that area and you should find it
I cannot find any info on the given model number, please check it.
The unit may not have a defrost timer. It may use an adaptive defrost board or defrost may be controlled from a main control board. |
THIS FORUM IS DEAD!!!!!!! |
