2 Pages12>
Dello
#1 Posted : Sunday, August 11, 2013 8:40:54 AM(UTC)
Dello
My side by side frigidiare. Model frs23lh5d refrigerator top portion of the freezer Is not getting cold and the top portion of the fridge is not cold. The compressor and fan is working
#2 Posted : Monday, August 12, 2013 3:23:52 AM(UTC)
Parts for FRS23LH5D - AppliancePartsPros.com
[COLOR="Blue"]
The compressor and fan is working[/COLOR]
Is this the condenser/compressor fan?
If yes is the evaporator/freezer fan running?
Dello
#3 Posted : Monday, August 12, 2013 9:11:53 AM(UTC)
Dello
I don't know where the freezer fan or condenser is located. The compressor and fan I'm speaking of is located in the back if the refrigerator at the bottom and these are still working. The fan is next to the coils
#4 Posted : Monday, August 12, 2013 10:02:50 AM(UTC)
Condenser is under the unit.
Evaporator/freezer fan is in the freezer compartment.
Take a look in the parts Control Parts section.
Dello
#5 Posted : Monday, August 12, 2013 2:11:18 PM(UTC)
Dello
Is this compartment in freezer behind the panel
#6 Posted : Tuesday, August 13, 2013 1:11:15 AM(UTC)
Yes.
Behind 10 and 10A in the Cabinet Parts section
Dello
#7 Posted : Tuesday, August 13, 2013 5:31:01 AM(UTC)
Dello
How do I know if the fan is bad
Dello
#8 Posted : Tuesday, August 13, 2013 5:33:04 AM(UTC)
Dello
i did see ice on the panel
#9 Posted : Tuesday, August 13, 2013 5:54:36 AM(UTC)
If there is 120 volts AC across the fan and it does not turn then it is bad.
I am not sure why you mentioned the ice.
If you remove the covers in the freezer and the evaporator coils are iced/frosted over to the point where the fan cannot pull air through them then you have a defrost problem.
Dello
#10 Posted : Sunday, August 18, 2013 6:16:56 PM(UTC)
Dello
I opened the panel and found ice behind the coils. How do I fix this problem
2 Pages12>
