My side by side frigidiare. Model frs23lh5d refrigerator top portion of the freezer Is not getting cold and the top portion of the fridge is not cold. The compressor and fan is working
THIS FORUM IS DEAD!!!!!!! |
I don't know where the freezer fan or condenser is located. The compressor and fan I'm speaking of is located in the back if the refrigerator at the bottom and these are still working. The fan is next to the coils
Condenser is under the unit.
Evaporator/freezer fan is in the freezer compartment.
Take a look in the parts Control Parts section. |
Is this compartment in freezer behind the panel
Yes. Behind 10 and 10A in the Cabinet Parts section |
How do I know if the fan is bad
i did see ice on the panel
If there is 120 volts AC across the fan and it does not turn then it is bad.
I am not sure why you mentioned the ice. If you remove the covers in the freezer and the evaporator coils are iced/frosted over to the point where the fan cannot pull air through them then you have a defrost problem. |
I opened the panel and found ice behind the coils. How do I fix this problem
